Viper-Rules!
I noticed today that my waterpump has been leaking slighlty. I have some coolant in the front belly pan area of the sled. I think this problem must have just started at the end of last season, since I never had to add coolant in the past. Dealer is going to replace the pump under warranty. Sled only has 3200 miles on it. Anyway's could some antifreeze in the bottom of the belly pan, wreck crankshaft seals? Just wondering if there is anything to worry about here, since my warranty expires next month?
yamaholic22
No i dont think you have to worry about the antifreeze in the belly pan getting to any of the crank seals or bearings. Now if antifreeze had gotten down into the crankcase somehow, then you may have something to worry about, but that isn't your case. Glad to hear they are fixing it under warranty, hope they do it right for you the first time.
bucky
Impeller seal... Had mine fixed under warranty.
