shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Here's some pics of my yellow handguards mounted on my SRX. I purchased them and the shock covers from Sinjin. They look great!
If you look close at the pics with the taller winshield my handlebars are bent. I'm not quite sure how I bent them but do you guys think it would work if I heated them up and tryed to bend them back?
If you look close at the pics with the taller winshield my handlebars are bent. I'm not quite sure how I bent them but do you guys think it would work if I heated them up and tryed to bend them back?Attachments
shortstop20
- Mar 6, 2005
Here's 2 pics of my winter wonderland, but most of the snow is rock-hard now!
The first pic was during the middle of the storm. You could only see about a 1/4 mile there. It got worse later too. The 2nd pic is the snow pile from our driveway!
Total for the storm was about 14" here. We ended up getting another 5" on that Wednesday also. The wind has been blowing so bad here though lately that the drifts became rock hard fast.
rancidjo
your sled is looking good...
wish we had some of that snow here....
i bent my bars back by taking the bar hooks out, putting a bar in the end and slowly bending them back, although they weren't quite as bent as your looks....2000kms later they are still holding up. i didn't use any heat as mine were just slightly tweaked
T.S.U.Filmz
Just buy a set of pro tapers and call it a day alot better bar and there not going to bend like that.
n2oiroc
dont heat them, it will weaken the steel!
mulderdad
Looks great with those handguards ss.
mul
mul
2001_blue_sxr
- Oct 20, 2005
- New Liskeard, Ontario, Canada
- www.vanducchiracing.com
makes me wanna go yellow too...looks great
shortstop20
- Mar 6, 2005
Maybe I'll try the bar trick. I figured heating them up would make them weaker so I wanted to ask before I did it. I'm not going to invest in a set of new bars either unless they're under $100 or so. Not sure how much longer I'm going to keep this sled.
shortstop20
- Mar 6, 2005
2001_blue_sxr said:makes me wanna go yellow too...looks great![]()
The yellow looks even better in person. The camera doesn't really show the real shade of yellow. Makes it look dull and crappy looking.
T.S.U.Filmz
You can get a set of ProTaper SE that bolt on for $50
03viperguy
this man speaks the truth!n2oiroc said:dont heat them, it will weaken the steel!
Why not use the adjustment from the steering rod unde the exhaust, are the bars bent or just cocked one direction?
shortstop20
- Mar 6, 2005
From what I can tell they're bent. It wasn't like this at the beginning of the season and then I noticed it on like my 3rd day of riding.
yamaholic22
yes dont heat the steel, it will undo the affects of the tempering and weaken the steel. My buddy bent his pretty good on his '98 srx and just slowly bent them back as someone else said, with a bar on the end of the bars. It's not your steering stem that is bent is it? They are kind of weak on the '98s.
shortstop20
- Mar 6, 2005
No I don't believe so, I looked at the stem briefly and it looked to be straight?
Srxspec
Your #1 performance shop!
Pretty sure I have a extra set of bars. I'll look tomorrow, they're yours all you have to do is come pick them up.
03viperguy
oooooo, that sounds like a deal
Yamahammer485
Dont heat the bars to bend them, it weakens the metal alot. Friend did that on his bike and the broke after bending twice as bad on his first ride. Just get a new set as already mentioned.
Shortstop, I recognize you from snowmobileworld. There is so much on this site that ill be here weeks just trying to look at everything!
shortstop20
- Mar 6, 2005
Yamahammer485 said:Dont heat the bars to bend them, it weakens the metal alot. Friend did that on his bike and the broke after bending twice as bad on his first ride. Just get a new set as already mentioned.
Ya, I'm there every once and a while. It doesn't ever seem like there's much going on there though. I visit this site, Snowmobile Fanatics and HCS everday though.
BoRnWiThBlUeBlOoD
how big of a bar riser would i have to get to make up for the height of the stock handle bars and and extra two inchs, i have a set of pro tapers but i havnt really wanted to experiment with them and end up wrong... is there anything else i need to change besides a bigger riser??? (throttle cable, brake cable, etc)
