Cory_090
the top cable of my powermadd throttle cable extenders snaped, what do I order ? i was told it was just a regular throttle cable but its way shorter and has a little ball on the end rather than a cylinder shaped piece
i dont have to buy the whole extensions again do I ?
thanks
Cory
thanks
Cory
If I understand your question correctly you need a new throttle cable?
If that's the case the mountain sleds have longer cables, IE the MM 700 has a longer cable than the SX 700, etc.
Hope this helps.
Greg
Hope this helps.
Greg
yamaholic22
call powermadd and see if you can get parts for it.
Cory_090
just got back from my yamaha dealer, had to buy the whole extensions again
rip off, they should have replacement cables like that in stock, most everyone has them so why not be able to just get the cable
