Changing gaskets on exhaust valves??
jaydaniels
Amherst NS
Does anyone know how to get the exhaust valves apart to change the gaskets in them. I have them off the motor put can't get the cable out.
I rotate the servo and the cable is extended enough for the cable to slide out of the Valve. Make sure that you keep them in order. This is for my 03 Viper not sure if it is the right way to do it but that is how I do it. ;)!
