russ
what is larger in size a 1 1/4 stud or 1.175 im having a brain fart.
need to keep looking into my stud size and if im safe ive got 1 1/4 on my new hacksaw track and it seams to be hitting the fron heat exchanger on the front of the fins
thanks
thanks
Cuzino19
1 1/4 is 1.25"
mulderdad
Is your track set to spec?
Too loose and yer gonna shave some aluminum.
Possibly get a leak then you go squeek!
I would tighten the track up a bit. Did you measure the studs before you put them in?
I just got finished cuttin 96 studs on my wifes vmax b/c they were too long.
just my 2 cents,
mul
just my 2 cents,
mul
russ
help with math
the track came prestudded from richmotorsports on this group site
i had a yamaha dealer install the track so i would hope it was right
it so damn hard to measure the studs on the sled.. but the paper work
said they are 1 1/4 extream max studs. not sure how they measure there studs. would anyone have there web site
thanks again for all feed back
Russ 03 viper
Russ 03 viper
mulderdad
How much have you ran it with the new track? Did you install protectors?
I had to tighten my track several times last year after replacing my stocker.
1" track with 144 woodys 1.18" studs.
I was hitting exchangers also. Just kept tightning track a little at a time, run it a little, tighten a little.
Is there much "hang" when the rear end is off the ground?
mul
mul
mul
mul
russ
just had track installed it only has about 2 miles on it
i have a 03 viper it came with protectors on heat exchanger and
tunnel.. i have studs running down the center so it miss's the protectors and
it seams to be just skimming the fins of the exchanger
russ
how much hang would you call normal.. and ill go measure and update
thanks
thanks
