Neonblue
Sorry, I posted this originally in the wrong forum. I didn't realize that there was a tech forum.
I've got a couple of problems with my 96 yamaha vmax xt.
First, I don't have the adjustable front suspension where the rubber caps can be pulled off and adjusted.
The sled doesn't really feel like it's "darting" because the the whole sled slides right and left. But it could be darting. I'm about 50-75 lbs more than the last person that rode it.
I did notice that I'm missing two bogie wheels (left front outside and middle right inside) and the rubber on the other wheels are missing. I picked up new bogie wheels to replace them all around, but I'm not sure if this would be the problem. Anyone know if this would cause the issue?
I was thinking that perhaps I didn't have enough pressure on the front skis. I'm not even sure if the front struts are in good shape? They look ok from the outside, no dents, etc... But if the bogie wheels are not the issue, how would I
a) tell if my front struts are bad (if they are, is there a shock inside that can be replace or am I looking at replacing the whole thing?) Do I have to buy real yamaha shocks?
b) Adjust the sled so there's more pressure on the skis? Since I'm heavier, I would put more pressure on the back which would theoritically lift the skis.
I just can't see how to adjust the sled's suspension at all...
If I wanted to put better shocks in, anyone have any recommendations for -cheap- but good shocks that will work? Again leading to the strut/shock question... Is there a shock in the struts?
Thanks for your help!
