Adjusting Pro-Action for the plushed ride.
wisviper
Wind Lake, WI
Looks like my Bender Re-action suspension will not be hear for my first trip.
So I am looking to adjust the stock to the plushed ride I can.
I believe lenghtening the front limiter strap most of the way and adjusting the rear shock preload mid way ( I am told that I can make the suspension less plush by loosening the rear preload to much...causing the suspension to couple to quickly).
I also have a set of quick adjusts on the transfer rods set at the lower line (cannot remember which way to adjust those?...towards the top for plusher ride or bottom)
Oh yea.. I have an 02 Viper w/shock update.
Thanks guys!
bigger gap on top for the transfer rods,adjust your back shock with a little preload,and front shock about half way.But pull up the limiter straps.
How far should I pull up the limiter straps..I thought lengthening them would give the front of the suspension more travel?? Thanks
