Supersized Srx
leeko
Chicago
Super-sized
mtn srx
yes, they are nice sleds. i really like my mountain srx. i put 2002 srx everything on it. heres a picture of me and my mtn srx in january 2005 at the lake chelan sno-drags. i won 1st in the 700,800 and 2nd in the 900
sx6,
The seat is a boss hi-rise flat-top, 136 rail extension from Tracks USA and the tunnel is max perf.
Front end work
Hey Leeko....when you long traveled that front end did you change out the radius rods and tie rods to MM or SXR trye or did you just keep the SRX stuff?
Thanks in advance,
Madmatt
Maddmatt,
Maximum perf. wide front end kit aluminum radius rods set at 43'' ski stance. Viper spindles and lightweight Viper trailing arms. Viper shocks modded my pioneer perf(changed shafts to ones that had eyelet mounts) with 2.3 mm/kg straight rate springs.
Leeko,
Are u running Viper shocks in the rear skid? Do you have viper transfer rods or SRX rods? Are your transfer rods bottoming out? I have a 2001 SRX with the stock skid, SLP 136" rail extensions, viper shocks and viper mountian tunnel extension. I am running Viper transfer rods in the rear hole and when the suspension is compressed the rods bottom out and it doesnt seem I am getting all the suspension travel. Just curious if you are running into any of these problems? Thanks.
P.S. Your sled looks sweet!
Kickstand,
I have Max Perf. Viper transfer rods in the rearmost hole. I have a rx-1 center shock and a Viper rear. When the rods bottom out it couples the the suspension no longer letting the 2 shocks work independently, making it harder to compress the skid further. I don't think you are really bottoming the skid but just getting into the coupling. Have you rode it yet?
You can get someone to help you compress the skid and try to get it down to the bump stops or you can take the shocks out and check to see if the skid will cycle through its entire travel.
Leeko
