SXV motor mountss
softail
Webster, ny
Help, my son just bought a 2002 SXViper and we noticed the front motor mount on the clutch side is broken. We removed the mount and when viewed from the front there are two tapped hole on the right side of the block and one on the left. The bolt is sheared off flush in the upper right hole with nothing in the bottom right hole and the bolt in the left hole has enough sticking out that I can probably remove it with a vice grip. The bracket that connects the rubber side to the block side has two holes on each side of different size and nothing lines up ( I believe the bracket is bent ). Can anyone explain what is involved in making the repair? I would hate to have to pull the motor to remove the broken bolt.
P.S. I have seen a post that says the SRX mount has three holes and would work if I don't have electric start, I don't.
