Oultman
I have been really going through hyfax lately, so I decided this time to replace them I would take out the rear suspension and check everything out. I have a '99 Sx 700 121" inch track. This is the first time I have ever tried to take the suspension of a Yamaha out. Anyways, I managed to remove 5 of the 6 bolts, but the 6th one will not come out. It is located at the front where you put your feet. The other bolt kept on loosening even when I was undoing the one thats stuck, so now that bolt is out but there is no way to get the last one out, it just turns but never unthreads. Is there anyway to hold the thing from turning. Hope you guys can help Thanks
try this
put the other side back in and slip an open end wrench behind it before you tighten it. Crank it down TIGHT, then try and loosen the other side. Slip the wrench out, and remove the other one. Maxdlx
Oultman
Thanks maxdlx, that was a brilliant idea, it came out no problem
