temp light codes
adam4by4
SE Lower Michigan
when I start my 98 srx 700 the temp light blinks 3 times then goes off does anyone know what this means or what it is supposed to do if something is wrong (trouble codes)
Well That Is A Good Sign, It Means All Is Good And Nothing Seems To Have A Problem . Everybodys Srx Should Do This If Not , And It Does SometHing Different Something Is Wrong. It Just The Checkin The Temp On Start Up To Insure Everything Is Below The Temp Sensor Max Temperature,
Ride It!!!!!!
Jp
