suspension set up
yamaham
Southern Ontario
What is the proper way to set the preload on the suspension springs?. If a length is given for your front springs of 9.75 to 10.25, is this dimension set with all weight off the skies(sled jacked up), with it sitting on the ground with machine weight on them or should the rider be sitting on the sled? Thanks for any help.
dimensions are a guideline to get you in the ball park...ride will determine more or less tension to your preference, sled jacked up or shocks out of sled and set, adjust from there....CP
