red700rider
I bought a new belt for my '97 SX700. The old belt was worn to 33 mm and the belt is running below the sheave. The new belt I bought (Yamaha 8DN-17641-00) is only 33.5 mm not 35 like the specs call for. I have one set of spacers (I think the smaller ones). Should I look for a different belt? Will adding a thicker spacer bring this belt above the sheave or is there something I else I should do?
you can add a 1/2 washer to the sheaves too....was the old belt a 8dn or 8ch??
red700rider
The belt was also an 8 DN. Is it a different width than the 8 CN? If so should any adjustments be made when using the 8 DN?
a 8dn is a stronger harder belt you might need more force to hold it....I can give you a pretty nice clutch set up for that sled...
greenhorn
- Feb 24, 2004
I need that!
I've got the same rig, and I'm gonna need a belt, should I get the 8DN or the 8CH? If I should have the DN I would very much like that new clutching set up!
The 8 dn is the ticket....way better belt....do you want a clutch kit or just make the stock clutching work with the new belt
greenhorn
- Feb 24, 2004
Mr sled!
thanks for all the info! i got ahold of Larry today at North Country, very helpful guy--and yes I would like the whole clutch set up, primary and secondary, as i ordered an 8DN from Larry today--he's got good prices! thanks again!
I will get you a good kit and then what to do to change the stock setup....actually Larry can sell you that too...he has the same one I would tell you and he can get the parts as well. Let me know if you still want the set ups??? or if you want to hit up Larry.
red700rider
I would very much appreciate the clutch setting. One question I have about clutch setting is does driver size have anything to do with how I set my clutch? All dressed up for riding I am 240 lbs. Also I am running with a stock 3/4" track but will be upgrading to a 1 1/4" track.
Stock Clutching w/ 8dn belt change rollers to 14.5mm, rivets both holes 3.6g, if it overrevs then load the tip a tad heavier.
Perf clutching w/8dn belt, 8ab weights, 2.4g in both holes, 14.5 mm rollers, Y-S-Y sec spring, 1 engagement shim, 48/43 helix, green sec spring at 70. 1 piece head gasket, bore silencer, notch reed stoppers and jetting at 145 on #1 and 143.8 #2 & 3......then check the overrev...should be really close.
greenhorn
- Feb 24, 2004
I got the new bearing today; what I thought was a good deal, turns out I still need the inner race as it is sold seperatly! Ha Ha! thats Murphy for ya! i think I will get the performance clutching set up and parts from Larry, seems like I'll need some new mains too huh? Maybe I'll be ready for watercross! (have to hurry though!)
keep me posted on your progress....
