Longnecker
- Nov 3, 2003
Riding 2002 srx7 in -15 to 32F conditions and DES is always coming on at 1000 ft. elevation as soon as power valves open. Stock jetting, any one have a jetting suggestion?
make sure there is not anything loose on the sled...a tap on the engine anyplace will cause that to go off.
Go up 1 size on the main jets. Mediocre fuel & lean jetting makes em go off a lot on the 02,s.
ecopter
Like Turk said, go up one size: 148.8, 147.5, 147.5. This is one size leaner than the '01 and one size fatter than the '02 stock. Most folks don't realize that the gas they burn contains 10% or so ethanol and that will affect the mixture (lean side). Change 'em to the above indicated and you will rarely see it again.
Jon
Jon
