Rambunctious
so i will be replacing my track.
I understant that the easiest wat to get the drive shaft "out of the way" is to do the following:
pull driven clutch
remove speedo box
remove chain case cover
remove bottom gear
slide shaft to left
release set screws and replace left bearing ( preventative maintenance)
drop right side of shaft to remove track
(do all the suspension disassembly... been there)
replace track
reassemble
now............
is there a spring clip that needs to be removed
is there a similar bearing on the crank case side? should it be replaced, or is it bathed in gear lube
any other things I should know
I'm and enginerd so I catch on quick, jsut have not disassebled this on my srx before
thanks
pic for reference
Ramb
pull driven clutch
remove speedo box
remove bottom gear
slide shaft to left
replace track
reassemble
now............
thanks
pic for reference
Ramb
