Bent steering?
BLUEBY
minneapolis
Hit the side of a stump or rock, don't know because i was traveling at a good clip. Got home and nothing appears to be bent on the outside or under the pipes, nothing loose in the steering but my handle bars look to be slightly cocked to the right but not much at all. I read the tech pages but is there any easy way to check to see if i'm straight without taking it down to the dealer.
check the toe in if your real worried, or its not handling right.
my guess is your just noticing it because your looking real hard for it.
I put a good tweek in a radius rod, and it didn't seam to make any difference, so I left it. that was in the winter of 99
