89 Exciter fouling plugs? :{
InSaNiTy!!
Alvinston, Ont
HI all !!
just bought an 89 Exciter with parts sled 93 Exciter SX is the parts sled... the guy i bought it from has done some modding to it, the drive cog and braking system ..the top end of the motor with slide carbs, handle bars, skis are all from the 93 SX ... the thing is I keep fouling plugs especially if I use #9 plugs ... its not oil fouling but gas fouling .... 2 days ago i rejetted from 155's to 150's in the main jets but its still the same.... the plugs come out wet wtih gas... this happens even at WOT.. when i put #8 plugs in I am able to feather out the throttle and clean her out .. some times it takes awhile but it will clean out ... cooler plugs not a chance have to change them.. has anyone got any idea what it could be? Input would be greatly appreciated
disassemble the carbs. Clean and check them out to see if you may have a loose jet. Also check the choke circut. Chack for free play in you choke cable when turned off. You could even have the floats sticking. Brad
