bleedspurple
- Dec 16, 2005
I have a 00' SxR 700 with Hauck triples. I went through the carbs pretty good or atleast I thought so. I am having alot of low end bog. Enough so that I can't even throw as much snow as a 120!
At midrange it winds out good, top end seems fine. Idles like a champ with no hesitations. Starts on 1st or second pull. Also seemed solid on the stand this summer and fall. Ran like a champ last year. Fresh gas and plugs already in.
What am I missing?
Thanks for your help!
What am I missing?
T.S.U.Filmz
check your TORS
terret725
when u did the carbs did u touch ur fule screws? might want to check and make sure theyre at 1 1/2 turns out. also did u take ur jets out and make sure theyre clean might have a pluged poilet jet.
yamaholic22
1.5 turns on the fuel screws isn't enough with those pipes. What are you running for pilots? Also could be your clutch setup. What are you running for clutching? How is your belt deflection (center to center) and offset?
DoktorC
2 turns out on the screws...Make sure your pilots are clean!! Run a small piece of wire or a tip clean from a torch threw them.
bleedspurple
- Dec 16, 2005
Thanks for the replies. Went through the carbs again and it worked. Must have missed something.
Did you clean out the air jet's most people miss them.It could be a worn beldt also.
