Bender Transfer Rods
adam4by4
SE Lower Michigan
On The Bender Hot Rods There Are Lines To Tell Which Level Your On Witch Way Is For Mor Transfer Up To The Top Or At The Bottom At The Top Right (lines Being 1-7 Bottom To Top #7 Would Be Most Transfer Right??)
Don't worry about lines or numbers with transfer rods. You only need to look at the "gap" increasing or decreasing between the rods and the plastic spacer when you turn it. More gap, more transfer..... less gap, less transfer. Equal on both sides!
