Bluebozz
- Dec 4, 2003
99 srx 700 with shaved head and thick base gasket
clutches are stock new 8DN belt
goes straight to 8600 then climbs to 9000
how much tip weight is stock and how much do I need to add?
I was thinking about 200 rpm per gram is that right?
how do rollers effect maxx rpm, I do have some 14.5's I could put in.
any help would be great
Specs and some info on clutching that 99 is in the Tech Section on the main page side bar. You may need more then just more tip weight to bring it down.
vmaxjohn
it's usually 100rpm per gram of weight on Yamahas.
You might go with a weight profile that suits your style of riding, heavier down low and mid range, the stock profile is an all arounder.
Sure had fun riding witchoo again Bozz! how was Chicago?
Bluebozz
- Dec 4, 2003
chicago was great as usual
did you get a good ride in Sat.?
are you still planning on a ride this weekend?
vmaxjohn
we had a great ride! we got stuck untold numbers of times, and the back country was crazy fun. the trails were hosed though, oh well
We're planning a ride for Friday starting in Gaylord. It's supposed to be rather warm though, so it'll be limited to low miles, the girls are going too.
Other than that, we've got some vacations coming up, so it'll be mid march before I can ride again, if the snow's good, I'd love to hook up with you again Bozz!
