Expected Transfer
i have the stock non adjustable rods right now but i think im gonna swap out the washer on em for better transfer what should i use instead of the washer for max transfer?
get the 2.5 mm top spacer for more transfer. the coupled skids will never have the monster ski lift of other sleds, but they will hook up as well. I want my skis on the ground. Maxdlx
so just go find a 2.5 mm washer? will this max the rods out? i want it at max or just below max so i dont screw the w arm
that will take it to almost max, anything over stock can cause w arm problems. Maxdlx
I have a vmax xt and bender ts3 transfer rods .... fully adjusted out with the thin washer on top ... still can't lift the skis ... at all... I think it has to do with the soft and saggy rear suspension on these sleds... going to put a viper cente shockin it and see if that helps ... if not I will moify the stock rods to give about 1/2" more gap...
ok what do i gotta do to get maximum transfer outa my stock rods... which spacer do i take out and do i need to add anything?
last year i took the top spacer out of the transfer rods cranked up the center spring sofend ther rear spring and let the limiter straps out as far as i could and still couldent get the skis off the ground
Is this what your trying to do? This is with Bender adjustable Hot Rods. Shock springs. 120 studs. I'm 200 lbs dressed to ride. But it is with the first year Pro action plus skid.
i took the small washer already on the stock transfer arms, put it on the bottom and got rid of the thick washer...that wiith the ripsaw track i cant keep the skis on the ground
(yes this is uphill, but you can see what i mean) and i only weighed 150lbs dressed last year...
