TimeBomb
went for a ride last nite. i noticed that occasionally, usually at an idle my engine diagnostic light flashes fast 7 or 8 times and then quits. does anyone know what that means? i can't find my manual to look it up
Trussman
TimeBomb......there is a link to viper codes in the "techpages"...........
Seems it could be related to the powervalves....
TimeBomb
k thanks
TimeBomb
ok i found it. it says either "disconnected", "short circuit", or "locked" does anyone know of what to look for with these 3?
TimeBomb
well i thought i found the problem tonite. i took my pvs out to clean them and i found one stuck. so i cleaned them really good and put them back in. started it up and revved it a couple of times and then it started fashing again. anyone have any suggestions?
ok, same code??
place sled up on a stand, take off servo cover, start sled, turn idle down under 900rpm, does the servo motor cycle the valves open?
TimeBomb
yes same code. i'll try that next week
