The Snakester
Hey i am trying to adjust my power valves and I'm not sure how to cycle the servo motor my dealer says it is not nessesary but we all know better so anything will help. Thanks
MAINERACE
- Aug 8, 2003
Me Too
Hi i have the exact same question..
did you ever figure out how to actuate the servo on the viper??
thanks
thanks
BigMac
MAINERACE said:Hi i have the exact same question..
thanks
It's not necessary on a Viper ER, since turning on the key will activate the servo. On a no-battery Viper, you need a special cable (Bender part number PVT001 for example ) that connects to an external 12-volt source and plugs into the harness under the right-side kick panel. That will activate the servo so you can adjust it.
edunn69
Start the engine and lower the idle down to around 900rpms and you will see the servo motor open the valves. Then just mark where it is and adjust the valves.
