adam4by4
can anyone help me out with rear suspension set up for a 98 srx 700 im bout 240lbs need to know what to do to increase stiffness and help stop bottoming off of med size jumps/moguls im not looking to air it out but a little air never hurt. My sled does not have ohlins unfortunately so any help will do. Oh and me loosing weight is not an option ...lol
600srxman
you could put the long travel rear suspenchen in it that would help and to loss a few pounds would not hurt i there just kiding
adam4by4
I dont wanna buy nothing else just set it up the best i can for the stock suspension without ohlins .What do i adjust to add pre load or can it be raised up at all and how do i set it for the stiffest setting ? once i know this ill play around with it anyone know any websites to try ? I have the front set up perfect
sandmanmike1
They do sell a heavy duty shock spring that is 11 inch long.
adam4by4
Ill Lookinto It Thanks
bluewho
wind the springs tight as they will go and put the fra on hard thats the top i believe.
Adjusting suspension
A tip:
You have instructions how to adjust the suspension in the owners manual.
If you don´t have one you can view it and save from:
http://www.yamaha-motor.com/assets/service/manuals/1998/lit-12628-01-95_764.pdf
It´s not printable but it´s a lot better than no manual at all.
A tip:
yamaholic22
set the fra to hard if its not stiff enough for you and set your springs for a 50/50 control rod gap.
