mulderdad
Hey all.
I went out last week on a hardpacked feild with my old 8dn belt.
Belt had about 2000k on it. Rpm was at 8300 spot on.
Went out for a rip two days ago and was overreving at 8600-8700. The only thing I did was put a brand new 8dn belt on before I went. We had about ten inches of fluffy snow. Was it the snow or the belt or both? I was over at my buds tonight and he said it is my hauck stingers causing the overrev due to lack of back pressure?
Thanks,
mul
Thanks,
mul
it could be both or one or the other. But I would guess the loose snow is the cause but how can you base that on one ride...
yamaholic22
a new belt will raise rpms. Check your center to center and alignment. May have to add weight to the tips. Also check all bushings and rollers and weights and pins. A worn anything can cause binding and make clutches act goofy.
yamaholic?? i always thought the new belt would lower the RPMS clutch has more material to work with causing the rpms to drop a little bit and an old belt will raise your engagment but lower your top-end just confused on that could you please explain how that works for me? Thanks, Tom
I have allways found a new belt will lower rpm,s. High Barometric pressure will raise rpm,s. A sunny clear crisp day can rreally make the sled sing.
A new belt lowerd my rpm's by 100.... dunno.
yamaholic22
sorry boys i should've clairified more. I have actually found it to go both ways, i worded it kinda chitty. I did not mean that it is a rule of thumb that a new belt will raise rpms, but i have found it to happen on several occasions. I'm not sure if this would be attributed to the compound being harder before it has gone through many heat cycles, creating a little more belt slippage before it is broken in, or if there is that much tolerance in the length, not sure. But i have found this to be the case before. Also, its important to wash a new belt with hot soapy water before using, there is a lot of dust and debris left on them from manufacturing and from sitting on the dealer shelf for a year. Wash them up good to keep good contact between belt and sheaves.
mulderdad
My alignment and belt deflection are good.
I don't have the tool to check center to center.
Is there any way of using a soft measuring tape around both shafts?
I will take her out for another rip tomorrow and post the results.
Turk it was a sunny crisp clear day.
thanks,
mul
thanks,
mul
mulderdad
Hey holic, do you use just regular dishsoap to wash a new belt?
I have about 15k on it (ten miles or so) should I still wash it?
thanks,
mul
thanks,
mul
yamaholic22
Yes i use just regular dishsoap to clean my belts and clutches, with water so hot you can barely touch it. And about washing it now, i'll just say this: you're clutches and belts can NEVER be TOO clean
