Turk - clutch question
Mills
Elk Mound, Wisconsin
I have a '99 SX 600 with the head gasket, dropped one tooth on tope gear, 0.92 Camo track with 96 Woody's Excel studs down the center, viper long travel suspension, C&A pro-sport skis and silencer mod.
I put your aggresive trail clutch set up in it and it was great. I destroyed a track last year so I decided to go with the Camo 1.25 Predator track and do away with the studs. Do I have to make any changes to my clutches because of the 1.25 track or should the sled perform about the same?
Mills
Your gearing down should compensate for th taller lug track. Clutching won,t allways be 100% & might need some fine tuning. There are also 2 600,s.Some of those set ups are for twins which are clutched differently then a triple.
