clutch problems with my 136 viper
yamiman
grand forks north dakota
02 viper with 136"x 1.25 track. sea level elevation, stock primary and secondary. also mbrp race can. 23/38 gearing with 8 tooth drivers. my problem is that on hardpack it will run the 85-8600 rpms, in deeper lighter snow it will only pull 7800-8000 rpms. also when i hit a snow drift sometimes my belt will spin in the secondary and i know that its not because of being wet. should i take out more tip weight(but then i would over rev on hardpack)
and for the belt slip put in a stiffer secondary spring? any help would very appreciated. ;)!
