slikRsrx
Refering to using choke only.I've tried every combination and never touching throttle,as you guys have said.Full choke,half choke,feather then off let idle for a bit.Doesn't seem to work on my 01 srx,if I let it idle untill the heat exchangers are warm,then take off always fouls #3 plug no matter what. Do you guys think i'm letting it idle too long?If i replace that plug with new it will run all day never fouling again.BTY just had dealer go through pv and carbs.Any info would be greatly appreciated.
98srx6
try turning your fuel screws in a half turn.
