Trailing arm question?
Viper Sniper
Northern Illinois
Will a pair of T-arms off a 2000 Venture 700 with the shorter spindles bolt right up and fit on a 2000 Mountain Max 700. They both have the same short spindles so I'd think they would work right???
yep.... both have 25.5 degrees castor
looks like where you could get into issues is with the vt600,vx600 some of those have the 186.5 headpipe length, the sx,srx,mm, all use the 149.5, double check the spindal length.
i.d marks on tube that will work for ya are: V, R, S
