hddwgtl
- Dec 21, 2005
I have a 2003 Mountian Viper that is over heating. Has anyone tried using "engine ice" coolant?
auji700triple
How good are you Mixing your coolant??
n2oiroc
i use redline water wetter and it really helps! it should work the same.
auji700triple
Or, What Conditions Are you running?? If no snow is flicking on your coolers it could be a problam, or no Rear sno flap?.. i dont know.
BigMac
hddwgtl said:I have a 2003 Mountian Viper that is over heating. Has anyone tried using "engine ice" coolant?
The stuff is propylene glycol. It starts to slush up at -23 F. (although won't freeze solid and expand until about -50, according to the rep whom I ran into at my dealer.
Probably great for dirt bikes, doubt it has any advantage in snowmobiles and does have a potential downside in those vehicles. IMHO
hddwgth,
We need some data to help you. i.e. snow/trail conditions, temp, any mods. Are you heat exchangers getting hot in the back? Did you recently change or drain some of your coolant?
Mtnviper
If it's overheating on hard pack, install a set of ice scratchers. It will solve the problem in those conditions.
03viper159
May have air in your cooling system, if you are running pipes you will probably need an opticool head gasket.
BigMac
I'd probably start by bleeding the cooling system. The Vipers are prone to overheating if any air gets in there.
hddwgtl
- Dec 21, 2005
Bleed system several times to remove air,never noticed any. The only mod is to the airbox. The problem started when I changed a hose under the clutch, the coolant has never been changed.
Thunder Valley
Stay away from Engine Ice! I've had that stuff come out of bikes like mud.
Water Wetter is decent. Did you add the second heat exchanger yet?
