srxtim26076
- Jan 24, 2005
my 2000srx700 cable appears to be put together wrong.
I assume that the cable goes to the underside of the disk with grooves. There are two slots in the disk. Which slot do the cables go into?
auji700triple
ttt for yah
srxtim26076 said:my 2000srx700 cable appears to be put together wrong.
Go here and print these out:
http://www.totallyamaha.com/snowmobiles/aaTECH/YPVS/YPVS.htm
Cable one and two go in the same groove. Cable 3 is longer and wraps aroung the servo further and into the next hole. If you study the one diagram on that page you will see how it goes.
