viperino
anyone know how much effect, if any, a change in the "roller diameter" in the primary have on rpms?
alot, it changes the effects of the weight, a smaller roller will lower the rpms from begine thru the full shift, it makes the weight act heavier then it is. The larger the roller the higher the rpms all the way thru.
viperino
thanx for the help
