Trying to change clutch weights.... old ones won't come out!!
Waterfoul
Grand Rapids, MI
Clutch is apart... bolt is out, weight won't come out! Is there some kind of bushing that the bolt goes thru that could be holding the weights in? Drawing isn't real clear about this...
.... I'm out on the garage waiting for a response!! :o|
Mike
two set screws on either side of the weight and a long bushing that will slide out once the set screws are loosened.
yep, you need to loosen the 2 set screws with a 2.5mm allen wrench, then the pin will slide out and the weight and 2 washers can be removed, make sure you replace the 2 washers when putting it back together.
I tried to put the screen print of the clutch for my machine up here but I can't seem to get small enought download and still be readable.
Part listed for the 600 is the 8CR... so why did I pull out the 8DF from a sled that is supposed to be stock and worked fine?
