Digatron EGT gauge install?
Viperlover
Sycamore, IL
I am trying to install a Digatron 3 window gauge on an 02' Viper. It says in the instructions that it gets its tach signal from the lighting coil. Where the heck is that?? Also, it says for sleds with High output ignition, you will need a different sensor for the install. Does anyone know if the Viper has the high output ignition? I know the 02' SRX has it, but not sure about the Viper. Any help would be appreciated. Thanks.
