dustydawg
Can anyone tell me what the head torque specs are for a 98/99 600 MM twin? They are leaking a bit.
SX/VmaxTwin Style Heads: 16 ft lbs you can find all this in the tech section. if your heads are leaking, it sounds like you may have other problems like a head gasket leak. if you replace your head gasket, check the head with a straight-edge for warpage.
dustydawg
16lbs...holy cow! I tightened it down a bit the other day guessing at 35 lbs just to stop the leaking...and it worked. I must have a warped head!
Thanks for the info.
