will the stock srx spindle steering arms work on viper spindles??? reason why i ask is because i want to buy viper trailing arms and viper spindles to put on my 02 srx
no, you need the viper upper arms as well. the only way you could get away with it is if you went with newer venture spindles, they use the same stearing arms.
Thank you BTV. i think ill pass on that idea now. more headache than it worth to
Mtnviper
Tom
I have an extra set of Viper spindle's. If you decide to do the swap, let me know.
im going to be working on a project (srx diet) when i get up to michigan this spring for vacation. i saw some aftermarket viper arms for a good price but i think that i may be going the wrong way since i have to put bigger spindles on. i was also trying to bring it up an inch in the front but decided it probably wont really be noticed. seems almost defeating the purpose unless i found some light weight spindles but thats even more $$$$ for now i am just going to go with some cb performance lightweight trailing arms light weight brake rotor from maxxperf and max's steering arms.
