helix question
You won't notice any difference on bottom but it will raise your rpm and the backshift will be better. Is this something you already have. If not I would buy one with different angles.
How would a 47/43 multi raise rpms vs a straight 47? I thought if the same intial angle intial shift out would be the same but with diff backshifting characteristics when coming out and back on throttle?
intodeep a shallower finish angel will raise your peak rpm but it will backshift better as it does'nt have to climb back up the steeper angle. srx600 I don't think you will want a 56 degree starting angle as it will shift out too fast and bog.
