Put new risers and handlebars on vmax
fastassyamaha
Lake Orion MI
Website
www.totallyamaha.net
Pic of 6" handlebar risers on my vmax
view
view
Just wanted to see what you guys thought, I didnt get to good of pics of them but ill get some later, there 6" pivot risers i got off ebay that are for choppers and the handlebars are for drag bikes i got off ebay also as you could tell i dont like spending money im only 16 and have no job... no one is hiring, I was worryed about the strength of the risers beeing for a chopper and all but i tested them an had nuthing to worry about they were really strong just like stock if not stonger, dont mind the pro taper pad i just took it off my bike to see how it would look im gonna get a factory effex yamaha pad for a bike..........but one thing i need some help with, the wires the stupid plugs are huge and need to figure out how to hide them??? thanks
Looks real good. Get out and test the riser if you are unsure.
BTW...forum rules say not to post the same thing in different sub-forums.
Looks nice. Was thinking about doing the same to my VMax. Other than unbolting the handlebars and cables and such... how much work is involved? Do you need to lengthen any of the cables? Brake line?
With my 3", my brake line is stretched to the max and had to lengthen the throttle cable.
Instalation was easy and straight forward, and is super easy if you have a friend to hold the bars while you mount the riser block. Also, mark your clamps so you know which side is the front and rear. That tip will save some time later down the line..
Yaeh installation was really easy and took about 45min-hour max just becuase you have to drill out the rivits on the grips and drill new holes in the new bars, as for brake lines and that everything was ok the throtal cable is tight it fits but if you wana feel safer get a longer one or the extention kits. make sure you get the pivot kind though becuase you need to bring the bars more forward if you dont bring it forward your throtal cable will be to short. you will like it alot better if your and agressive rider you can control the sled much better. :yrules:
how is the riding position like when u are sitting down?
can u stand up and grab the bars good with the 6" risers? how tall are u
sitting down its kinda weird but its not unconfortable i wouldnt go any higher then 6" if you plain to sit down to and use stright bars to, im 5'6 not that tall so if your taller it would be great for you, standing up its 5 times better then stock its nice
Just for everyones information. I rolled my bars forward on a 2002 V-max about 2" this also lifted them up about 1.5". I really felt it improved the handling and ride (because it moved riding position ahead) No cost, nothing to worry about with cables and easy to return to stock if you don't like it. Would suggest you measure from a reference point on the rear of the sled before moving to get your current location. I used a rivet in the tunnel to the center of the hand grip as my reference locations. This may not be a good idea for short sit down type riders I'm over 6ft.
Note: After doing this the throttle and brake levers need to be re-adjusted to your comfort location. Just loosen and turn very easy to do.
