WONT IDLE
dave hughes
nova scotia
I HAVE A 88 EXCITER 570E.It wont idle.it will start and idle on the choke,but when you take off choke it dies.I have cleaned both carbs,replaced fule pump.The sled runs on the high end but wont idle.I tried to use like this but it squared a piston.I replaced both piston and bored 10 thow.Please help i dont want to burn anther piston.I am thinking crank seal,removed pullcord,dont see any sign of oil,maybe center seal?It seams not to be runing on clutch side,lots of spark.I lift the choke cable on clutch side it will idle high can someone help please?
With it idleing as best you can, spray choke cleaner around the clutch and mag seals. If it's leaking it will suck it in and rev up some. I've changed some in Kawasaki engines and I drill a hole in the seal and use a slide hammer to pop it out. Then lube the new seal and tap it in around the edges if they need replaced. Double check your carbs and make sure "all" the jets and passages are clean. I use a drill bit to clean the jets. Just twirl it in your fingers to remove the crusty crap.
Check your carb boots between the carbs and the block for holes/tears. (sucking in too much air) this might be why it will run with the choke on. Cheers.
