aftermarket gauges on a viper??
03viperguy
Alton, NH
where you guys put water temp gauges and the like. thinking about getting a water temp gauge, but want to mount it nice and clean. any pics/ideas? thanks biys :) :yrules:
srxsrule had the exact set up with water temp on his viper a few years ago. i was privaledged to ride it for a few miles with his cpr set up in it. when i saw the guage set up and the performance i was hooked. i have the performance part down, i would love to find a set of those avengers dirt cheap to round out my viper package as well. nice set up there PV-7. ski
looks good, but I only want the one gauge, preferably a small round autometer gauge. sled is stock, no need for more than temp gauge.
Thats the same thing as me, I dont want to have to spend to much money so I was just thinking of a small round gauge also.
damn, a lot of people want it but noone has it lol! I ought to make up a kit and sell it ;) high demand, NO supply lol!
Gauges as requested
Here is the gauge I installed because I to was interested in accurate temp. and not just an idiot light. This setup seem to work fine for me. Very inexpensive also should not cost more than $60 or so. My 780 Viper runs at between 150 and 160 most of the time even when running wide open trail riding for long periods of time. When I veer off the trail into powder even with one running board in the snow the response on the digital guage is almost instant and you can watch the temp. decrease. You can easily find power under the hood and will have to run a wire to the sensor. Also have to drill and tap 1/8 npt for sensor in the head. Very easy installation. Hope its what your looking for.
Summit Racing part number sum-2984 digital gauge
Summit Racing part number sum-G2988 water temp sensor
Hi Performance Engineering #900-277 instrument mounting pod
--mac--
thats exactly what I was lookng for! just want one I can put in the cooling line though, so I dont have to drill the head :) that looks great, thanks for the post!
Temp light
Can't tonight I have no coolant in the motor. Should be able to on Sunday so check back then.
I got a powederlites gauge kit, and am planning on cutting the ends off that mount to the handle bar and leave teh facotry gauge in its current position and sandwhich the mount between the plastic and the gauge, it will fit a single 2 5/8" gauge I might install my EGT there that I got from redline if it doesn sell. Should look money, look under www.powderlites.com under turbo section you can see the a rxi gauge panel with a boost gauge mounted should work in the viper we shall see.
aluminum spigot adapters
Who sells (or makes) the adapters to place the sending unit in the coolant line?
John
