2000sxr600
Ok, I have a 2000 Yamaha SX600R and I was going to get a 1.25” predator for it but I have found a great deal on a brand new track that some one took off a new 20005 Arctic Cat ZR 900, the track has no miles and I am trying to get it for 300 us shipped to my door….good deal eh?
Anyways I am also getting 4” rear suspension drop brackets so I am not worried about clearance issues in the back of the sled but what about the front end of the sled. Bulkhead ext.., will I have any clearance issues?
Would the top speed be a major difference between the 1.25” predator….and the 1.375”?
thx
Andre
thx
Andre
aSRX600guy
should fit with all stud protectors removed
n2oiroc
it should be noched. it might bolt right in. also 4" rear drop is a LOT! that is like 8" at the bumper!
2000sxr600
i know that with the suspension drop bracket i dont need to take the rear protecters out but what about the front bulkhead protecters?
2000sxr600
hey n2oiroc dont u also post on HCS?
anyways so if the track is notched, i would not need to take any of the protecters out?
yeah 4" sounds liek alot.....this guy here on hcs used the 4" on his sled
http://www.hardcoresledder.com/forums/index.php?showtopic=113952
the brackets are adjusttable to 3 to 4" so....
n2oiroc
if the noches are at least 1/4" deep it should go in with all the protectors. and yes, im on hcs a lot. here is a pic of my viper with less than a 2.5" drop.2000sxr600 said:hey n2oiroc dont u also post on HCS?
2000sxr600
nice viper!!!! what size track are u running? 136x15x???
i heard that the notches are 3/16 on the zr track...would that clear with the protecters still on?
yeah i guess 4" is a litle bit 2 hight, well atleast for trail ridding.
i guess im gonna go with the 2 - 3 ¼ Inch Drop....how is handeling in corners with ur set up...is it tippy?
what company did u buy ur brackets from....waht is envolded with instaling them?
n2oiroc
its a 136" x 15" x 1.75". if the noches are only that deep than you probably need to remove the protectors. its easy enough to do. either way thats a great track, youll love it! handling isnt tippy at all. i really havent railed the corners too much (tall paddles are slippery on hard shiney snow!) but it seems close to stock. i am using stock rx1 brackets and rear shaft. when you deciede to drop it, let me know. the center needs to be dropped too, and not the same amount. the measurements need to be precise. an 1/8" off will case it to bind!2000sxr600 said:nice viper!!!! what size track are u running? 136x15x???
2000sxr600
i am going to be ordering the brackets 2 morrow...what do i have to do to drop the center....so i have to buy something else?
i am going to buy my brackets here
http://www.timbersled.com/CustomProducts.htm#S1
2 - 3 ¼ Inch Drop $84.95 and i will be setting it on the 3 1/4 drop
BTW, thank you for all the help
n2oiroc
the center mount just needs a new hole to be drilled. to run those brackets you will need to remove your board coolers, put the brackets on, rivet the coolers back on and then shorten the upper shaft of the rear suspension. expensive and not the best option. i would either2000sxr600 said:i am going to be ordering the brackets 2 morrow...what do i have to do to drop the center....so i have to buy something else?
A. run rx1 brackets ($14 each) and rx1 upper shaft ($25 used) $53 total.
B. p.m. srx2000 about his drop brackets. they are offset, so you can bolt them on and use the stock upper shaft. (about $75?)
I have CB and am at 3.25 drop. i dropped the center I think 1.5. I can't remember. i will measure it on Fri. Maxdlx
2000sxr600
ok thanks againe man, u are really helping me out!
i just pmed 2000srx....will i still have to remouve my board coolers? and do i still have to drop the center?
n2oiroc
the board coolers can stay on. the center will need to be dropped. once you deciede how much you want to drop it let us know and we can tell you how much to drop the center. another caution, the rear and center need to be moved forward, not strait down! the distance between all the holes has to be exactly the same as stock! i was 5/16" off and it was binding bad. it must be done with precision!2000sxr600 said:ok thanks againe man, u are really helping me out!
2000sxr600
the rear and center have to be moved foward....LOL this is starting to confuse me, i know what u are talking about but how will i know how much to move them up by
2000sxr600
sorry if u guys find im asking alot of questions...i just what yto know how to do this the right way the first time
n2oiroc
i cant get what i want to post, but if you take a string and hold one end to the front hole and swing it down, you will see it get closer to the front of the sled as it goes lower.2000sxr600 said:the rear and center have to be moved foward....LOL this is starting to confuse me, i know what u are talking about but how will i know how much to move them up by
2000sxr600
okay im kinda lost.....(im stupid, well atleast i feel stupid right now)
i uderstand i have to move them on the same asix, but how much further up
i see u edited ur post......do u think a my snwmobile machanic could figure this out by himself.....he is an expert with yamahas?
n2oiroc
for instance on mine with a 2.5" drop in the rear and a 1" drop in the center. (A is the front hole, B is the middle and C is the rear) b was moved forward appx. 3/32" and C was moved forward appx. 1/2". there isnt a specific measurement to get it forward, you just need to maintain the center to center measurements of each hole. for example (im just making these #'s up, dont use them!) if A-B is 12" stock, it needs to stay 12" dropped 1". if B-C is 15" stock, it needs to be 15" dropped 2.5". A-B, B-C and A-C cant be changed.
2000sxr600
i think this job is sounding to dificult for myself to do
( i just cant picture waht u are trying to say, maybe i should just go to bed LOL)
it would be so much easier if the CB brackets would come with a template.....im thinking of asking my mechanic to do the instalation for me...do u think he would know how to do this....how much time did it take u to do it on ur sled?
2000sxr600
im starting to understand the more i read ur post....i think i should still go see my mechanic, i would think he would understang eh?
OAKY, i though it over a bit and when to see how teh rear end was set up on my sled.....i understand most of what u are saying..the only thing i dont is how will i know how much to move the brackets (across)...
