Trying to figure out the angles on one of the helix's I have. I've looked it all over and the only marking I found was "2002B" engraved on the backside. Other than the spring twist markings of course. 2002B doesn't seem to correlate with any info I found on this site.
It came off a 2002 Viper, maybe I'll have to call Bender. Hate to have it sitting around not knowing what it si.
I have Benders heelclicker kit for ported srx's and am trying to figure out the same thing. I called them and they won't tell me. They say they don't know what is in that kit???? I think I'll take it out and send it to Bruce at Pioneer this spring. I want to buy his roller secondary kit.
Let me know if they tell you when you call. If they do I may try again.
they wont tell you!!
you can find out what it is exactly by putting it on a digital cad machine.
my machine shop here does it for me for $25, not cheap, but when a helix is a $100 a peice, better then guessing the wrong angles needed when you need another one.
you would also be surprised at the true angles some helix's are versus what they are stamped to be..........
Mtnviper
A while ago, I read on here, that the angle is marked on the helix under the bushing. You have to drive out (remove) the bushing to see it.
Well, I tried it, I pressed the bushing out and there were no markings under there either, good idea though.
Bender will not say what it is, thats enough for me, I won't setup another sled with Bender products, simple as that.
Thanks guys!
Thanks guys!
