maxis45
I have an 89' exciter with 1800 miles on it. Runs great. The only problem with it so far is that it bogs out in the deeper snow. But then i pick up the track and give it some gas, it goes fine. I don't know if it's the clutch or not. Many people have told me it's the clutch. But i just don't know. Someone please help me please???
Brad_69
Check your clutches out. Have the rear clutch checked for spring tension and how high the belt is in the rear clutch. On those sleds I have set the rear clutch tension from 16lbs to 18lbs, using a fish scale. To check the primary you will need a clutch puller. I would check your clutches out before some serious damage occurs. Brad
