RX Warrior skid in a Viper?
woolyviper
NE MN
Would the skid out of an 05 RX Warrior be a direct bolt in on an 03 Viper ER?
The rear mounting position may have to be changed, but other than that it should work?
does the viper have a tunnel extension? the warrior suspension is a 136" vs. a 121" on a viper.
it wll go in. you probably will need drop brackets. the rear and center mounts go farther back (i think around 7.5" ?). if you dont run drop brackets, you will need to use the stock rear shaft off of your viper suspension. i dont have the specs or measurements to install it, but im sure someone here or on the 4 stroke side can get those for you.
