Klotz premix for oil injection?
upnorthbacon
Gaylord
I have a gallon of Klotz premix from my bike left over. Will it hurt to run it in my viper through oil injection? I know they have the premix type and oil injection type, is it a gimick or is there really a difference?
there are differences, but you should be able to run premix stuff in the injection. HOWEVER, i would NOT go the other way, using injection oil to premix unless it states that you can or it may not mix correctly with the fuel and you may not have adequate lubrication.
I was told under no sercumstance put klotz premix in the injector. Get ahold of nosboy he's the one who said it. Maxdlx
What oil is it?
Is it R-50 or Super Techniplate?
See if you can find a part number on the bottle.
Rick
Both the R-50 and Super Techniplate are for PREMIX ONLY.
They also are for constant high rpm or modified motors.
Don't put these oils in your injector system.
Rick
