cmd951
- Nov 22, 2005
Try to change the front left bulkhead on an 03 RX1. Wonder if you have to remove both sides in order to get just the left one out. I have it stripped down and there are two bolts sticking out from of the steering U frame. The other two bolts stick out the side of the left bulkhead coming from the steering cross member which attaches between the two bulkheads. Need to know what to do next, can somebody please help!!!!! My theory is that both bulkheads have to be slid ahead an inch or two and then split a part in order for the front bolts attached to the U frame to be cleared... I would like to know what direction to take before going further.....
goliath
What did you find out gotta do the same thing any advice ?
goliath, I responded to your other post here: http://www.totallyamaha.net/forums/showthread.php?t=67721
