Roushrider81
- Dec 4, 2005
ok my sled has been leaking antifreeze for about a week now... it hasn't really been bad just a few drops here and there but when i went to look at it today the whole system was drained and it was all over the ground...probally about a gallon. any ideas about that???
and i just installed AAEN triple pipes on my 2000 sx 700 and the only problem i have is the clutch grabs at about 7 grand i want it to grab at 4.5 or 5000 RPM's what can i do change the weights...which weights would i need?? and i no some of you guys on this site have the same setup... what weights do you have on and what does your clutch engage at???
thanks alot guys
thanks alot guys
jwiedmayer
check the water pump area..
I would alsocheck the front exchanger, and the side ones and hoses to see if one has a hole. Maxdlx
change_up
What are you running in the primary now?
Roushrider81
- Dec 4, 2005
all i did was change the spring aaen sent me...nothing different to the weights
PowerValve-700
Yeah, common areas for coolant leaks are the waterpump seal and side heat exchangers. The side heat exchangers seem to crack in a common area (right under the rear suspension bolts). If you drop the skid you should be able to see the crack if there's one there. I had to get my left side welded once and right side welded twice. I brought my sled to someone who welds aluminum and he welded them right in the sled, I just removed the rear and middle bolts and left the front ones in so I could just swing the skid out to give him room to get at it. Oh and the coolant has to be drained before you can weld.
Roushrider81
- Dec 4, 2005
thanks guys i will check this out tomorrow and nice sig. i got that for a shirt
mikematthys
check the hoses i rubed through one of mine
Roushrider81
- Dec 4, 2005
lol i forgot to put a bolt in near the engine and it was leaking from there lol and with the clutch i just changed springs and now it is awesome...thanks for the help guys !
