Viper Jet size with Speedwerx billet head
Stephan
I have a viper 2002 witch C.P.R triple pipes, SPEEDWERX billet head 12/1
carbontech reed valve, R/3 roller clutch and heelclicker 2 speeds
i dond want to utilise the C.P.R triple pipe anny more ( to loud for my country )
but i like to keep the speedwerx billet head, but i really don't know what jet size for this set-up PTO= ? CENTER=? MAG=?
and what will be the clutch set-up with R/3 ROLLER CLUTCH AND HEELCLICKER 2 SPEED ??
THE ONLY CAM ANGLE I HAVE WITH THE ROLLER IS 35/31
IS SOMME ONE CAN HELP ME ????
Well are you running the reduced compression on this head for the pipes. The reason I ask is, I ran that head and pipes for part of a season. We put in the domes that allowed for straight compression across the board. I believe mine was around 132 psi all the way across. With my stock head I run 130/145/145 approx. For the best perfomance I would get the proper domes to achieve these number so you can run stock jetting or go with 145 across and run stock jetting in the middle and mag and go up a size or two on the pto.
