2 Coolant related questions...
S.S.Viper
Toronto, Canada
Just outta curiousity on my Viper
1..I've pulled my Carbs and drained them of coolant/fuel...but unfortutely the coolant ran outta the resovoir...I've since reinstalled the carbs...topped off the coolant resevoir and opened the carb heater valve...
Question: Do I bleed it...?
2. I've got a rear heat exchanger coming from SJ...I was thinking of lifting
the rear end pretty high when installing so not much coolant will be in the
little rear pipe that the exchange is replacing...
Question: Do I bleed...?
Obviously I'd cover both areas together...And if so...do I slighty lift the front end so the air heads towards the front...and undo the screw near the Carb Heater Valve until the Coolant squirts out when running?...
YOP
