I was out riding kinda hard and out of no where i lost a ton of power.
It will barely get to 50mph
feels like its only running one 1 cyl.( got spark on both)
I swapped plugs, compression is good, 125+/- on each side
it starts up if i give it gas, and if the track is off the ground it will rev out to about 7000-7500 tops, but with horrible throttle response.
I looked at the 2nd clutch and the buttons were worn so I replaced them and reassembled the clutch.
I did notice the tors light came on right when this happened but I believe i disconnected it and still no better.
the wires I disconnected and plugged into another goto a small switch thing under a white knob right above the carbs. looks more like an idle adjustment to me.
I am out of ideas other than a bad reed what could this be from?
